wheel adornmaents
jeedee
4
What is the official name of the pressed-on stainless-steel designs that occupy the center of a Ranger rim...2002, and does one need special equipment to remove them...? (I tried a search for "glamour rings"....86.) Thanx for any info.
superj
2,690
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
Do you have a picture? I am only picturing a beauty ring with what you are describing
8,372
Google: 2002 ford ranger wheel center caps
If the lug nuts are not seen and no screws then they just pry off
Get a small piece of cardbord and a pry bar
Put cardboard on the wheel and hook pry bar under the center cap, and pry it up, then move to a new location across from last place and repeat
These caps have cups that fit over lug nuts, thats what is holding them in place, just friction
85_Ranger4x4
17,966
SW Iowa
The factory tire change kit should have a rubber coated prybar incorporated into the lug wrench for removing the center caps.
Danno1985
105
MKE, WI
stock
stock
stock
Crown Vic Police Interceptors used the stamped metal "pancake" center caps, if that's the style your looking for, for a couple years, maybe 98-00, so if you're looking for a set, you may have better luck searching for "Crown Victoria center caps".
Here's a set. No special tools needed other than a flathead screwdriver or the end of the factory jack handle, as mentioned above. You will need collared lug nuts, however.
