Where to get trans mount?
The_Dealer
10
Macon, GA
Duh!
im looking for a trans mount for my 85 b2? im looking for a replacement mount that was on the a4ld. the newer mount that originally came on the fm146 wouldnt fit my xmember so i put my a4ld on one there, but its seen some better days. ive looked online and every one i can find is for newer b2's which is the same style that can with the fm146 that wouldnt work. i read about an 80's f150 mount working, is that true?
xkotyx
20
Waynesboro, VA
have you tried lmc truck?
The_Dealer
10
Macon, GA
Duh!
yup, seems nobody makes the mount for an 85 a4ld
xkotyx
20
Waynesboro, VA
oh man, sorry i couldnt help!
Got a pic of it?
I have a few kicking around, but I think they are all the new style.
Bryan22
4
So-Cal babay
94 extd
94 2.3
i just got one at autozone for my 94 ranger. think is was only like 30 bux. can't see the newer ones being too much different. basically the same frame and the same trans. take the old one with you and ask for one for a newer truck and have a look.
The_Dealer
10
Macon, GA
Duh!
the studs are closer together on the older ones. dont wanna drill my xmember because it will get front back and side to side play
What about switching to a newer crossmemeber?
4.0B2
151
Walls, MS
4.0 v6
make a custom crossmember... that doesn't hang down.. that doubles as extended radius arm mounts.. !!!!!!!
The_Dealer
10
Macon, GA
Duh!
mine is the high clearance one that is inside the framerails
4.0B2
151
Walls, MS
4.0 v6
well i'm jealous... mine hangs down... and mounts on the outside... that aint fair. lol.
The_Dealer
10
Macon, GA
Duh!
and i know im missin a bolt lol it was for illustration purposes only. i havent seen any like mine that go inside the frame. i actually think it goes on the outside like all of the others ive seen like that, but i think i put it on wrong when i put the trans in...o well now i can do a flat t-case skid
xkotyx
20
Waynesboro, VA
no some of them did belong on the inner framerails. i was reading about swapping to them somewhere to add clearance.
