Natedog
- Aug 7, 2007
- 5
- CA
- Ranger
I have two trucks...both 87 Extracabs with 2.9 V6 and A4LD. One is 4x2 and other is 4x4. I'm swapping my cab, bed, dual fuel tanks, posi rear axle, wiring harness, etc. to the 4x4. I've just killed my third A4LD, so am considering a 5-speed swap while I'm at this. The 4x4 has an electic shift xfer case. I also have a parts truck 83-85 (not sure which year as it's rolling chassis only) with a EDIT FM145, manual shift transfer case and 2.8 V6. I have the slip-yoke type driveshaft, on both my 4x2 and 4x4, but want to use the bolt on flange type of driveshaft with the new 4x4 setup...yes, I know I'll have to modify my driveshaft so that's not a problem.
Which 5-speed tranny to convert from my A4LD? Mazda, FM145 (Mitsubishi), FM146 (Mitsubishi, supposedly upgraded synchros over the FM145) or M5R1 (was told this is best and easiest to get parts for of the Ranger trannies), or?
Any drawbacks to these different setups? Different overall lengths?
