- Nov 13, 2018
- 4,466
- Canaan,NH
- Ford Ranger
- Engine Type
- V8
- Engine Size
- 351
- 2WD / 4WD
- 2WD
- Total Drop
- 3"
- Tire Size
- 235/55R16
- My credo
- If you don't have time to do it right will you have time to do it over?
If you don't want to buy a suction gun you can make a substitute like I did. Take the cap off a jug of dish detergent that has a pull to open cap on it, remove the pull cap, put a short length of 3/8 hose on it and clamp in place. Screw it onto a bottle of fluid, insert the hose in the fill hole and squeeze the bottle. I wash it out between uses and have used it for gear oil, too. I have another pull cap that I use when filling power steering fluid to avoid drips. I've never seen a failure using Mercon fluid and it's cheaper than synthetics, the key is to change it regularly.
