Whine in 1st 2nd and third in 94 Ranger
phyd3ux
Slc, Utah
I have a 94 Ranger 4wd 4.0 with the mazda tranny, it wasn't driven for a while, but now its got this kind of a weird low whine, when accelerating, and decelerating.. but when I have the clutch in, or if its in neutral.. nothing, it sounds normal. I recently replaced the shift boot, and the inner shift pins (not sure what there called, they hold the stick from doing a full rotation) and all the bearings a stuff related with that. So it shifts great. I just can't figure out the noise. It doesn't quite fit into the forum topics I have read so far. Any help or tips would be appreciated
stegomon
20
auburn/minot maine
fords and only
welcome to the slow tranny death....i am getting the same thing right now....but mine is in 3rd an 4th!!!!fun fun
kennykenny
4
Manahawkin, NJ
Mine too, I made the mistake of putting gear oil in it once. Been doing it ever since, shame on me for not checking first. But about 30K miles later at 180K it's still working just fine with the exception of that 1,2,3 whine.
phyd3ux
Slc, Utah
hmmm...
I guess I will start with checking the fluid. Its been a while since Ive driven it. And right before I stop using it, I tried to teach it to swim. That might have something to do with it, if somehow water got in there... maybe.
kennykenny
4
Manahawkin, NJ
I would just drain it and refill it, only takes about 2.5 quarts.
phyd3ux
Slc, Utah
Its atf right? Any particular type or additive? Transmissions aren't my thing.
PlumCrazy
2014 Truck of The Year
179
Millersport, OH
Solid Axle Swap 4x4
Mine has a whine when sitting in nuetral (input shaft bearing), so I drained it and refilled with Synthetic Mercon ATF and it is pretty quiet now.
-plumcrazy
JDF088
The whine is most likely caused by excessive wear on the gear teeth, I just pulled mine and when I took the top cover off I could see the wear on the teeth of one of the gears.
