Who here likes the AR platform?
Ranger44
23
Illinois
FORD
4.0 OHV
Cause I'm a huge fan.
Newest build.
The Jester Race
68
Sacramento, Kalifornia
Ford, BMW
2.9, 4.0
I'm not the biggest fan, but they are a fun toy.
Here's mine in various forms over the years.
This is it's latest incarnation. I'm still not quite happy with it.
-Jester
17,999
SW Iowa
It would be fun to get one but IMO they are kinda pricey for what they are.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Jester- I like your newest setup the best! I'm wanting to get a new one and when I do it'll look somethin like what you've got. This is my R-15.
Flash Gordan
Savior of the Universe!!!
7
South Jersey
Hey Rowdy what power scope is that? And how far away were you from that coyote when you bagged it?
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
It's a tasco 6-24 power. I was around 150 yards. He was laying down and I used a Herters 55gr fmj. I hit him on his left side and that was the exit. The bullet hit his shoulder blade and grenaded lol.
JoshT
1,877
Macon/Fort Valley, GA
Got one, and what I've used it I like it. Having what I believe is a short stroke problem, but my dad thinks it's cycling too fast. If I can get what ever it is fixed I think it'll be a fun shooter.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Josh- what kind of clip are you using? Mine does that some times with my spare clip but feeds good with the one it came with. Try another brand of clip. It might be only that.
4.0B2
151
Walls, MS
4.0 v6
I still have a stripped lower...with no other parts! I bought a pistol then started buying stuff for my b2, so... yeah. I'll build it one day.
The Jester Race
68
Ford, BMW
2.9, 4.0
Cycling too fast is very very rarely a problem, only ever seen in full auto guns.
Short stroking is also rarely a problem. Most symptoms of short stroking are also symptoms of a malfunctioning magazine. Magazines are cheap and easy to replace. It should be the first thing you check.
90% of all AR 15 malfunctions can be attributed to malfunctioning magazines.
If your rifle truely is short stroking here are some things to check.
1. If it is a new factory rifle, just shoot it more and keep cleaning off the carrier parts and lubing them. Chances are high that it is just too new and it will take a while for the parts to wear in and become slicker. The coatings that are used on these guns cause a lot of friction but will wear in shortly. If you still are having trouble after 200-300 rounds, look for other causes.
2. Check your ammo. Try different ammo. Try your ammo in a friend’s rifle. Look for pressure signs, flatter than normal primers, firing pin dents that have been pushed back up, holes in the primer, deep extractor marks, brass that has been extruded into the extractor hole, etc.
3. Check the carrier key for leaks. Look for signs that gas has been blowing out from under the key. Check the bolts for tightness.
4. Check the gas rings. A properly functioning rifle will usually work even with the ring gaps aligned. If your rifle works when they are unaligned, but doesn't when they are aligned, look for something else that is contributing to the problem.
5. Check the alignment of the gas tube in the gas block. Also check the alignment of the gas ports of the gas block and barrel. The gas ports are small, you don't have much room for error.
6. Pull the front gas housing off and measure the diameter of the gas port. Also measure the diameter of the barrel also as the size of the hole varies with the barrel diameter. For one example, on a Colt 16" lightweight barrel the gas port diameter is usually .063"-.070".
On a Colt 16" heavy barrel the port is opened up a little to approx. .075". The distance that the port is from the muzzle will make a difference also. On 10" barrels the port needs to be a little bigger, say .093", because the pressure drops off fast after the bullet leaves the barrel.
7. Check to be sure the buffer spring is correct and lubed nicely. I grease mine to keep them quiet.
8. Check to make sure the hammer is not sticking up too far and catching the firing pin on the carrier’s way forward. I have seen this a lot on rifles that have had a 'trigger job'. Metal was removed from the front of the trigger and from the hammer hook to get a nice trigger feel, but the hammer now sits much more rotated forward and will interfere with the firing pin. This happens the most with the hammers that have the notch on the top corner.
The notch will catch on one of the rings on the back of the firing pin.
9. Check the chamber for grooves or ridges left from a damaged chamber reamer. The factory tries to get more life out of the reamer, or had someone that is rough with it and puts a nick in the cutting edges. These ridges and grooves cause more grip between the case and the chamber wall.
10. Make sure the bolt and carrier are free to move forward and backward inside the upper receiver and that everything looks like it is aligned. Make sure that the magazine isn't hitting the carrier anywhere either.
-Jester
JoshT
1,877
How did I know that magazines were going to be the first comment I received. My magazines:
1 - 30rd Thermold
1 - C Products Aluminum 30 rd
2 - C Products SS 10 rd
3 - El cheapo Sportsman's Guide steel 10-20 rd (I've all but thrown these out)
They all do the exact same thing in my rifle, regardless of how they are loaded. All but the 3 cheapos work fine in dad's AR-15, and they work better in his than they do in mine. I've also tried a couple of dad's mags (can't recall brands) with the same results.
1) I hear you about breaking it in but I've already shot a couple hundred rounds through it, and the amount that it happens is unacceptable even for a new rifle. Comparing it to dad's again but his never did this straight out of the box.
2) I've tried about 4 different brands of ammo with the same results. Dad's shot my worst ammo and it worked fine.
3-4) I've checked these out once, but I'll certainly look again
5-6) I partially suspect this. After purchasing I had the original sight style gas block replaced with a low profile version to use with a scope (flattop upper). I had this problem before the block was replaced, but that doesn't mean it was lined up right from the factory. It is the 16" barrell, just not colt.
7) I also suspect this, but not sure how to check that it is the right one. As mentioned above it's 16" barrel and had fixed stock.
8) Ordered a JARD adjustable single stage last Friday. So if that's an issue not, it shouldn't be for long.
9) Will check it as soon as I have a chance.
10) Seems to be good there. I'll double check on the magazine, but I'm 99% certain it's good.
AngryLepercon
39
Maryland
Nope I'm not a fan. Lmao
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Lol no need to get so technical. He understood my point and meaning.
AmericanPride
I prefer the new ACR and SCAR. Much better platform in my opinion
AngryLepercon
39
Maryland
I agree. The two rifles on the right are colts. I have never shot them. I bought them as an investment ( non regulated)
Top on the right is a 12 gauge (head turner at the range)
Middle on the right is a 22 s&w fun and not expensive to feed (slide fire soon)
Personally. I prefer bullpups though. They fit me better. They are heavier. And just look cooler factory then most built AR's
