My engineer son-in-law and I built a HHO generator in a 4" ABS tube with stainless steel wall plates, draws 20-25 amps and bubbles really good...We hooked it up to the Ranger at the PCV valve inlet near the throttle body with a 3/8" tube and let it run.
At idle speed we noticed no difference. Then I pulled the connector off of the IAC and dropped the idle down to 400-500 rpm and he also covered the Airbox snorkle inlet with his hand, as I fed the tube into the PCV valve inlet. It idled normally with the HHO gas running the engine, proof enough for us that it was running on almost pure hydrogen. When we pulled the H fed tube out, the idle speed dropped down where the engine almost stalled.
We did that several times and said "damn, it works".
Check engine light came on and we reset it by disconnecting battery.
Our next design will be something to fit under the Ranger's hood without melting.
There is very little room to mount anything with the 3.0 FFV engine and the heat from the exhaust manifold will probably not help. There is barely enough room to set a 4" diameter canister in front of the A/C heater connections.
We saw one of the You Tube Videos where a guy had put a rectangular stainless steel box in the trunk (if you can call it that) of a Prius and ran it cross country that yielded an improvement from 48 mpg to 66 mpg. His rate of H gas production was controlled by a variac mounted on his consule next to the drivers seat connected to the output of a 1800 watt DC to AC converter in the trunk. Then he used the AC thru a diode rectifier arrangement (bridge or ?)to feed the H generator plates.
Another guy re-fed his H generator with water from the windshield washer contatner
and the suction from the bubbler pulled the water in as needed...Hey is that neat or what?
I've had one person try to sell me an $1100 H system from:
http://www.hafctechnology.com/index.htm
Looks to be the best one around and with proven results.
Another kit is priced more reasonable at $170 at
http://www.smacksboosters.110mb.com/
For those of you believers, let me know what you are using on your Rangers in a private message. Thanks.
JB, retired electronics instructor, with time on his hands to fiddle with technology
