why does my a-arm look wierd
goldxlt
Constantia NY
never noticed this before, my pasenger side upper a arm is different then the one on the drivers side, instead of being one "hoop" from the frame to the ball joint, i have one hoop off the frame and then a second that the ball joint sits on that attaches to the first one. is this a universal set up that the previous owner used or is it suppose to be like this.
gwaii
2010 OTOTY Winner
2010 Truck of The Year
66
haida gwaii
460
that's the way they come.
escort_gts
02/2012 04/2013 04/2014 OTOTM Winner
16
Fort Wayne, IN
4.0, 5.0
looks like an adjuster for caster
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
That is exactly what it is for, caster adjustment. And yup, it is factory.
It can be replaced with the newer 1 piece upper arm.
goldxlt
Constantia NY
:icon_rofl: well i guess you never know unless you ask, thanks. is it better to replace it with a one piece or keep the stock set up?
srteach
9
Ranger, F350
4.0L, 7.3 Diesel
Keep stock ... larger adjustment range.
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
But only on one side....so It's kinda pointless.
I'd just replace it with the one piece arm and install the camber/caster eccentrics while you have the arms out.
gwaii
2010 OTOTY Winner
66
haida gwaii
460
i'm wondering,though...why was that arm only used on the right side.is there limited room for adjustment there so it had to be built into the arm?the left side specs the one piece.
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
The only thing I could think of is so that they could easily set the caster to compensate for road crown?!
gwaii
2010 OTOTY Winner
66
haida gwaii
460
hmmm.seems odd they would design such a complicated arm for one side-seems like an afterthought,that's why i was wondering if there's not enough room for adjustment on that side.a different arm would be easier than redesigning the frame.
just a guess though.
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
I've replaced them with the newer one piece arm lots....never had an issue with aligning it after with camber/caster eccentrics.
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Just read through the shop manual...it is for setting caster split.
You are still supposed to install the camber/caster eccentrics and get everything evened up using them. Then you set your caster split with the adjustable RH arm.
gwaii
2010 OTOTY Winner
66
haida gwaii
460
ahhhhh.
still seems odd.
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Yup...the split is easily accomplished with the eccentrics on their own.
