Yep. Another question about tension guide durability
Saddle Tramp
748
Florida
How well do the redesigned ones hold up?
I have a 2011 with roughly 82K miles and am starting to worry about the wear the have. (Every time I change the oil I can hear a light rattle for a day or two.)
I'm not a diy-er so it would go to the shop.
What's the average lifetime of the redesigned versions?
Should I worry or no.
PS oil change regularly
Uncle Gump
Token Old Guy
13,462
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I think with proper maintenance using good full synthetic oil and Motorcraft filters,,, you should see 200K. But... I'm a believer. The haters will say different.
One thing I noticed with one of my 4.0L SOHC's years ago... after an oil change... the first start up I would get a rattle from what I assumed was the timing chains. I started filling the new oil filter before installing it... no more rattle. Been filling my oil filters ever since.
gw33gp
536
Costa Mesa, CA
4.0 SOHC
33"
I replaced my timing chain tensioners somewhere around 80-100K miles and am at 241K miles now with the second set and all seems to be well. The original ones were not bad when I replaced them. I just found a good deal on them and decided to replace them as a maintenance item because of all the bad thing reported about the early timing chain tensioners.
I still have the original timing chain guides. So, you with running the newer version, you should have many miles to go before having to do anything with them.
Saddle Tramp
748
Florida
Thanks guys! ?
