Yes, another poor mileage 4.0
Mike Tonon
Guest
Hey, I checked my fuel mileage the other day and it was a little over 15. There were times it was about 17 and times when it was about 12.5. I have 4.10 gears with limited slip in the rear. I wonder how much different it would be with 3.73 and open.
8,372
It would depend on your driving speeds
OPEN or L/S wouldn't matter
3.73 would get a little better MPG if most of your driving was on flat ground at 60-70MPH
Around town the 4.10 would do better
But the stop and go with an automatic is what lowers MPH alot
With an automatic you are burning fuel at a rate of 6-8MPH when stopped, that's the engine load when in gear, ain't alot but ain't 0 either, lol
Best MPG is with skinnier tires, and lower to the ground, reduced friction and less air resistance
Which most pickup trucks don't have :)
Mike Tonon
Guest
You know, I did think about putting an old set of 14x6 1980’s two-tone steelies, with the trim rings and chrome, black and red center caps. P205/75R14 tires would be a little narrower and a lot lower. A lot of those Rangers had 3.45 gears, though. 4.10 might not be good. How much would my mpg’s improve, though? Be nice to break 20!
8,372
You wanna break 20MPG with a 4.0l Ranger then drive to the top of the Grapevine in Calif, set trip odometer to 0, fill up the tank and drive down, refill at the bottom, calculate MPG :)
Mike Tonon
Guest
If I did several mods...
-efan
-tune
-performance exhaust system
-cold air intake
-high performance ignition system
-full synthetic fluids (and as thin of oils as I can use, like in the diffs)
-aluminum rims (which I have)
-port and polish intakes
-different gearing (I currently have 4:10’s)
-shorter/narrower tires, with smoother tread
-remove all unnecessary weight from the vehicle
-some other things I haven’t thought of yet
-and go easy on the gas pedal
...I don’t see why 20 is unattainable.
RangerDanger2
Tampa, FL
No Worries
Just filled up again today and getting 14.7 in-town after a can of Sea Foam. Put another can in today, I'll see how that does.
