2 vs 1 pc driveshaft.
Denisefwd93
74
South East PA
Engine Type
4.0
2WD / 4WD
I've read the swap tutorial on the tech pages seems pretty clear and somewhat low-tech.
Does it make sense to swap in a one piece drive shaft on a daily driver that is not going to be lifted more than 2 inches if at all?
The existing support bearing is not bad yet but it is "sloppy"
1994 supercab 4wd 4.0
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
No. It doesn't. On a stock truck with no real issues with the carrier bearing it doesn't make a lot of sense, since there are no performance gains to be had.
I did it on my truck when I swapped transmissions and needed a new drive shaft due to a length change.
When the carrier goes bad then I would do a cost analysis on it, keeping in mind that many after market carriers are not going to be nearly the quality of the original.
Denisefwd93
74
South East PA
Engine Type
4.0
2WD / 4WD
Thanks for the reply! I was looking, there are different sizes, one of the larger ones is made by anchor, so I guess they would have larger bearings possibly, possiblynot.
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
I don't know what makes one take one bearing or the other I just know you need the right one.
RonD
Official TRS AI
TRS Technical Advisor
8,370
canada
Just did the carrier bearing today on my '94 extended cab 4wd
$100can for carrier bearing
$38can for middle u-joint, it was bad, both end u-joints were fine
Just extra parts that can fail on a two-piece drive shaft setup that you don't have on one-piece drive shaft
Denisefwd93
74
South East PA
Engine Type
4.0
2WD / 4WD
Well I called a few yards nada I don't get it with these yards around here. there are quite a few yards selling on eBay but it doesn't look I'll get this one piece drive shaft for less than $100 unless a goodly soul on here as one. So for now I'm going to get the carrier bearing.
bobbywalter
TRS Technical Staff
TRS Event Staff
TRS Banner 2012-2015
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
it is easier to fix and understand than "her"
with a low power stock type engine and normalish tires....hell no. just like the cooling system...i just wouldnt fawk with it. but it is one of the things i hated most about my truck when i first got it....that hop it had. i was sooooo happy when i went to 1 piece... then i smashed it...:D
with bigger tires and mildish wheeling its a tough call.
the one piece shaft if you like to off road brings more risk of damage. i have destroyed quite a few unfortunately.
i am actually thinking of going to a two piece style like casey cravins come up with...it is brutally effective and uses a hardmount pillow block. you can build a heavy wall short rear shaft that is the same size as the front doing that and have redundancy and space by only keeping 1 spare.
sooo....not much call for that.
so whatever is most cost effective is what i suggest...if its within 50 bux it might be worth the effort.
Denisefwd93
74
South East PA
Engine Type
4.0
2WD / 4WD
I'm going to go for the carrier bearing I'm not a maniac I'm not going to be 4-wheeling other than snow in the winter time.I used to think it would be cool to go to the jersey and Delaware beaches but that doesn't really even interest me anymore.
Denisefwd93
74
South East PA
Engine Type
4.0
2WD / 4WD
Revisiting drive shaft issues. I do have the carrier bearing and imagine at some point we will be changing it out I've started wondering about 45- 55 mph shake in the truck. Hank insists that when he drove it back to his house the night I bought this truck, it did not Shake, when we changed out the transmission he didn't give any thought to phasing the two piece driveshaft I did my best but now, I'm wondering,
Are there any Factory marks to align the spline on these two piece driveshafts???
I found a discussion on another Forum here https://www.ford-trucks.com/forums/1411562-help-aligning-the-front-spline-on-rear-driveshaft-2015-f350-2.html
ericbphoto
Overlander in development
TRS Event Staff
GMRS Radio License
16,598
Wellford, SC
Engine Type
3.0 V6
3.0L
2WD / 4WD
6"
35"
In theory, theory and practice are the same. In practice, they are different.
I think there is an article in the how to tech section that explains this. If not, I know there are some great articles and videos online. Basically, you want the u-joint at one end of the shaft exactly 90 degrees from the one on the other end. Anything other than that and they fight each other as the shaft rotates.
This message composed solely of recycled electrons. Go green!
Denisefwd93
74
South East PA
Engine Type
4.0
2WD / 4WD
I did understand that and I did make sure we took the time to a line up U-joints but what I'm asking is when it was built and balanced, would there be marks?
ericbphoto
TRS Event Staff
GMRS Radio License
16,598
Wellford, SC
Engine Type
3.0 V6
3.0L
2WD / 4WD
6"
35"
I've never noticed any match marks on the ones I have worked on. I usually make my own before disassembly if I remember.
Denisefwd93
74
South East PA
Engine Type
4.0
2WD / 4WD
The rear end of the truck hops & shakes, not violent, but pretty good at 45 and higher, it doesn't seem to be the drive shaft cuz I don't feel it through the shifter and it seems to do it in neutral also. I'm guessing it's the rear end itself, seems like every vehicle I ever get has bouncing rear ends LOL
I had the tires rotated yes it did it before, tires rebalanced, yes it did it before and still does. I'm going to check the pinion U joint when we do the the drive shaft and carrier.
Craig0320
225
Mississppi
Engine Type
V8
5.0
2WD / 4WD
Break it right the first time. Fix it better the next time.
Mine bounces around 40.
Denisefwd93
74
South East PA
Engine Type
4.0
2WD / 4WD
Well... Ordered a one piece DS, seems they are all on Ebay. Picked a yard in the Phila area free shipping. checked and checked again. for for fitment.. all seem as the tech pages says.
Wish me well with this!
Lately it seems like any kind of highway speed gets the shake enough that the whole truck rattles now before it was just a slight Shake we'll see when we actually get working on, it just makes sense the to loose the carrier bearing
Staff online
Members online
Shran
April Truck of The Month
