Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Engine & Transmission Forums > V6 Forums > 2.9 Liter Forum
Notices
Reply
Thread Tools Display Modes
Old 10-05-2010, 10:58 PM   #1
Lucky'sRangerSusie
Lucky'sRangerSusie's Avatar
Vehicle Year: 1986/1987
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: Mud and occational climbing in creeks
Lucky'sRangerSusie is on a distinguished road
Question 87 Ford Ranger 2.0L sputtering problem HELP!! We've tried everything we can think of!
I have a 1987 Ford Ranger 2.9L that a few months ago started sputtering and dying when I let off the gas. When I first start it up the truck idles perfectly. Its after I accelerate that the truck starts to sputter and dies if I don't keep my foot on the accelerator.
What we've tried:
new plugs and wires
new distributor, cap, rotor, module
new fuel filter
new air filter
new rear fuel pump
new fuel regulator
We tested the fuel pressure its normal.
its not the temperature sensor.
o2 sensor is not hooked up and hasnt been since a long time before the truck started this so its not the problem.
__________________
*Lucky*
1986 Ford Ranger
8" Sky Jacker Suspension
35x12.50x15 Super Swamper TSL
Lucky'sRangerSusie is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 10-06-2010, 09:16 AM   #2
Acepilot1023
Junior Member
Acepilot1023's Avatar
Vehicle Year: 1988
Vehicle Make: Ford
I use this vehicle for: Muddin'
Acepilot1023 is on a distinguished road
Default
I don't really know what to tell you to fix it in the long run, but you can adjust your idle so that it idles a little higher and you don't have to worry about it cutting off.
Acepilot1023 is offline   Reply With Quote
Old 10-06-2010, 10:36 AM   #3
Psychopete
Psychopete is just really nicePsychopete is just really nicePsychopete is just really nicePsychopete is just really nice
Default
Can't really adjust the idle on these - the computer is what controls the idle speed. Adjusting the screw on the TB is going to screw up the base TPS voltage., though it seems it's purpose is for idle speed, it is solely for setting the base TPS voltage.
Honestly sounds like a very dirty throttle plate - try cleaing the IAC valve and the throttle body, or at least check it for crud around the throttle plate edges.
Pulling codes wouldn't hurt, but it's a little more involved because you can't use a check engine light, but still can be done with a test light (or analog meter, hell probably even a 12v buzzer). I tape one to the hood while it's open if the check engine light is burnt out (or not present), and watch from within the cab.
Psychopete is offline   Reply With Quote
Old 10-06-2010, 11:40 AM   #4
jhammel85
Lurker
Posts: n/a
Default
I agree that you should look into the IAC. It'll do wonders for how it'll drive. It could partially shut or shut all the way. Might want to check the TPS voltave too while you are at it. Perhaps the TB butterfly is too far shut along with a dirty or faulty IAC.
Old 10-06-2010, 11:51 AM   #5
Lucky'sRangerSusie
Vehicle Make: Ford
Default Will try tonight.
Thanks a million guys!! I will try cleaning that out! I'll post whether it fixes it or not.
__________________
*Lucky*
1986 Ford Ranger
Reply
Bookmarks
Tags
1987 ford ranger, 2.9l, dying, sputter
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2018 / 959 Media LLC / All Rights Reserved
