rpm at 70 mph
1ftcr14u3
leonard , tx
i have a 91 with a 3.0L and automatic trans and 3:45 rear axle ratio
and the the tach shows 2800 rpm at 70 mph which seems high to me .
what rpm do other comparable rangers run at 70 mph ??
8,370
Welcome to TRS :)
Calculator here: https://www.crawlpedia.com/rpm_gear_calculator.htm
At 70MPH with 3.45 axle, 28" tires and transmission in 3rd(1.00 ratio) engine would be at 2,898 rpms
In OD, 4th(.75 ratio) it would be 2,174 rpms
Correct tires diameter matters so change that to match your vehicle
A4LD automatic has 3rd at 1:1 ratio, OD/4th at .75:1
So your transmission is probably not be shifting into OverDrive/4th gear
1ftcr14u3
leonard , tx
thank you , that must be it .
1ftcr14u3
leonard , tx
i did a road test today . at 70 ( around 2700 rpm ) i manually shifted from OD to 3rd
tach went to 3500 rpm . Wouldn't that indicate i was in OD ??
85_Ranger4x4
17,833
SW Iowa
With 3.73's, 31" tires and a 3 speed automatic (third is 1:1 like your third) I ran 2700ish at 60mph.
Smaller tires and 10mph more I could see being over 3k even with the slightly higher gear.
With stock 2wd sized tires I am going to say that is the nature of the beast. Keep in mind the national speed limit was 55mph when your truck was built too.
8,370
Yes, but it would also indicate you have a 4.10 rear axle ratio, not 3.45
Use the calculator, its just math, but calculator makes it easier
I used 27" tires size
70mph
.75:1 ratio OD
Then use 1:1 ratio 3rd
If rear axle was 3.45 then
in OD RPMs should be 2,254
in 3rd RPMs should be 3,005
If rear axle is actually 4.10
OD RPMs are 2,679
3rd RPMs are 3,572
Which reads like what you have
You are there we are not, so only you know the variables like tire size and rear axle ratio
SPEED is also a variable if it has not be tested, if tire size was changed then speedometer is not correct
Use Mileposts to check if odometer is correct, or use GPS APP on smart phone to check speed
Constants are .75 OD ratio and 1.00 3rd gear ratio in an A4LD, these don't change
