2011 Disc brakes on 2008
nezzie09
Canadian Military - Active
Georgetown Ontario
4.0
Hey - wondering if there is any way to get a 2011 disc brake rear axle with 2 ABS sensors to work in a 2008 truck (has one sensor on the top of the pumpkin).
Any help would be appreciated!
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
If you have the whole axle I think I would look at just swapping over the brake bracketry and such. It shouldn't be that hard. Take your shafts out, and then 8 bolts from each axle and you should be able to bolt all the disc brakiness to your existing axle.
Probably the easiest way to do it as it will leave all your existing sensors intact.
Mac
183
C. Wisconsin
2000
199
4.0
Tech library show the 2020-2011 axle tubes are 3.25" dia same as Explorers, brackets won't swap over?
Dave
Dirtman
Former Middleweight Moss Fighting Champion
13,326
41N 75W
Engine Type
2.3 (4 Cylinder)
2WD / 4WD
2WD
It's up there.
Total Drop
It's down there.
Round.
I poop in the furnace.
nezzie09
Georgetown Ontario
4.0
Dave
This is part of the reason I want to swap the axle and not do a mustang disc brake swap!
Ill figure something out and report back!
nezzie09
Georgetown Ontario
4.0
Appreciate the reply. Looking for the larger axle tubes as well.
Will figure some way to get this going... Worst case, I'll drill and tap the pumpkin ?.
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Will figure some way to get this going... Worst case, I'll drill and tap the pumpkin ��.
That may be about the only other option.
But for some reason I could swear that the later axle tubes necked down at the end.
nezzie09
Georgetown Ontario
4.0
I'll let you know soon enough, but specs for bearings listed for 2011 show the same bearing sizes as the explorer axles, so it shouldn't neck down.
Bird76Mojo
1,265
IL
Engine Type
V8
28 spline 8.8 necks down.
31 spline 8.8 shouldn't neck down.
GB :)
nezzie09
Georgetown Ontario
4.0
GB :)
100% for the 2010-11?
Timken shows the exact same part #/specs for the 2011 Ranger rear wheel bearing as they do for the 2000 Explorer..
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
2010,2011 rear axle shafts are 28 spline but have the same big bearings as the 31 spline shafts.
the diff does not have a tone ring. there are tone rings on each axle shaft.
check out the pics in the thread just posted
Staff online
Shran
April Truck of The Month
