No Spark Problem
smudvapor
152
Youngstown, Ohio
"Lets stop thinking in terms of limitations and start thinking in terms of possibilities."
Longshot....
But check your TFI, make sure its secure. I had one rattle loose on a 300 6 once.
Also, make sure the dist cap is tight. Those can rattle loose to.
I replaced the distributor and replaced the cap and rotor, the TFI is also secure.
smudvapor
152
Youngstown, Ohio
Do a wiggle test on the ignition module connector. I had one that would only work if I pulled it out a little bit so it wasn't fully seated.
Did the wiggle test with a friend and in the dark but nothing changed.
rusty ol ranger
2.9 Mafia-Don
7,494
Michigan
177 CID
You try pulling codes?
smudvapor
152
Youngstown, Ohio
rusty ol ranger
2.9 Mafia-Don
7,494
Michigan
177 CID
