Truck is less gutless at 2000ft elevation?
Strelok
2
San Francisco
2.9
I use my truck exclusively for transporting my motorcycles to riding destinations.
I've taken it over Grant's Pass on I5 three times now, lots of elevation changes.
It seems that up in the mountains I don't really have to shift out of 5th on anything even close to flat and the truck will do 80-85mph in 5th with my foot on the floor.
Don't get me wrong, it's still gutless, but on relatively flat surfaces I don't have to think about shifting
Once I get back to the bay area closer to sea level, where things are much flatter, the truck will not do over 65mph in 5th with my foot on the floor and I often have to downshift just to maintain highway speeds on the slightest incline.
I'm wondering if this ghetto cold air intake the PO put on is causing me to run lean, or what else it could be.
To be fair, by the time I get back to the bay I've been running for 8 hours, so maybe it's heat soak or something.
My truck is a 1990 STX on 31x10.5 tires, supposedly 60k on a rebuilt 2.9L.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
First, what rear gears do you have?
Second, if an elevation change gets you better power you may have a MAP sensor going back and giving screwy readings.
Strelok
2
San Francisco
2.9
I believe this means 3.73 gears.
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Looks like 3.73 to me.
3.73 with 31s may be a bit steep for a 2.9. Mine was much happier with 29s and 3.73s.
ericbphoto
Overlander in development
TRS Event Staff
GMRS Radio License
16,598
Wellford, SC
Engine Type
3.0 V6
3.0L
2WD / 4WD
6"
35"
In theory, theory and practice are the same. In practice, they are different.
Yes. 3.73 / limited slip
This message composed solely of recycled electrons. Go green!
Strelok
2
San Francisco
2.9
I'm sure it would be but they came on the truck and it looks mean, so I'd rather not downgrade.
The tires are 80% anyways.
ericbphoto
TRS Event Staff
GMRS Radio License
16,598
Wellford, SC
Engine Type
3.0 V6
3.0L
2WD / 4WD
6"
35"
That truck looks great. It would run pretty happy with 4.10 gears if you want to keep that tire size.
2trux
16
Albuquerque NM
Ranger
2.9 L
From the looks of it that is a hot air intake. I would look for a factory air filter box to put back in.
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Right, I'd be thinking about 4.10 gears.
And ditching that hot air intake.
Staff online
Members online
Shran
April Truck of The Month
