Rear diff issues/questions
that09ranger
Forum Member
💻 TRS Socials
U.S. Military - Active
conway
AR - USA
Vehicle
2 inch level
goodyear trailruner ATs 235/75r15 29inch diameter
hello, i have a 2009 ford ranger 2wd, 2.3L i4. when i hit the gas semi hard, i hear a grinding/slipping and a delayed acceleration. i was wondering if this would be a rear diff issue, or if anyone has experienced it and has some advice. feel free to ask questions if you have any. thanks
crawl under and look for leaks at the pinion. jerk on the pinion to check for up/down/sideways movement.
it will have considerable rotational movement, that is normal.
transmission in neutral, jack one rear tire and rotate it slowly feeling for "spots" or grinding/noises
does it also happen when L is selected?
how about when you turn the OD off?
