DISCLAIMER: Activities and vehicle modifications appearing or described at The Ranger Station and it’s pages may be potentially dangerous. We do not endorse any such activity for others or recommend it to any particular person – we simply describe the experiences and opinions of other Ranger/Bronco II owners. If you choose to engage in these activities it is by your own free will and at your own risk. Any and all modifications will likely cause a vehicle to behave differently than stock. Some modifications may significantly increase your risk when driving the vehicle or be dangerous in some driving situations. Use good judgment when engaging in any activity or making any modifications. Do not take unwise risks. Consult a certified professional if you are not sure of something. The Ranger Station and the authors of these articles assume no liability for how any particular individual chooses to use the information presented here. Some of these modifications may void your vehicles warranty. Please also read our Legal notice HERE.
Original Version:
This section replaced the old Tech Library of the original website that can still be found HERE. (No new articles added here after 2018)
2019-Present Ford Ranger Tech:
If your looking for tech specific to the 2019-present Ford Ranger, click HERE.
Other Info:
Engines:
Ford Fuel Injection & Electronic Engine Control Book (1988-1993)
Duraspark Basics
2.8L Duraspark Conversion
2.8L Chevy TBI Swap
2.3L Turbo Swap Wiring Diagrams:
1988-1991 Ford Ranger Engine Wiring Diagram (.pdf)
1988 Ford Thunderbird 2.3L Turbo Wiring Diagram (.pdf)
1988-1991 Ranger 2.3L Engine Wiring Diagram
1987-1988 Thunderbrid Turbo Coupe Wiring Diagram
1990 Ranger to 1988 Turbo Coupe Wiring Pinouts (Excel Spreadsheet)
Ford Explorer 4.0L To Bronco II Wiring
5.0L Electronic Fuel Injection (EFI) Wiring
5.0L EFI Wiring Harness
Charging System:
Charging System Check
Dual Batteries
Cheap Dual Battery Setup
130 AMP Alternator Swap
Lighting:
High Beam Upgrades
Fog Light Rewiring
2007+ Ford Ranger Fog Light Modification
2007 Ford Ranger Turn Signal Modification
Trailer Lighting
Properly Wiring Accessories
Using Relays
Miscellaneous:
Wiring Defined By Color & Diagrams (1983-1991)
Ford Ranger Horn Modification
Volvo Electric Cooling Fan Swap – Volvo Relay
Fuse Box Location / Diagrams
Other Interior Items:
Explorer Overhead Console (Compass & Outside Temp) & Lighted Mirror
Add Factory Power Doors
Gauges:
Instrument Cluster Wires (1993-1994)
Tachometer Install
Accessories:
Using Relays
Selecting Wire Size
Ford Ranger Radio Diagrams:
1983-2006 Radio Wiring Colors & Diagrams
1983-1990 Radio Typical 1 of 2
1983-1990 Radio Typical 2 of 2
Ford Ranger Radio Wiring Overview / Colors
1990-1992 Ranger Radio Wiring Diagram
1993 Ranger Radio Wiring Diagram
1994 Ranger Radio Wiring Diagram
1994 Ranger Premium Radio Wiring Diagram
1995 Ranger Radio Wiring Diagram
1995 Ranger Premium Radio Wiring Diagram
1996-1997 Ranger Radio Wiring Diagram
1996-1997 Ranger Premium Radio Wiring Diagram
1998 Ranger Wiring Diagram
1999 Ranger Wiring Diagram
2000 Ranger Wiring Diagram
2001 Ranger Wiring Diagram
2002 Ranger Wiring Diagram
2003 Ranger Wiring Diagram
2003 Ranger Premium Radio Wiring Diagram
2004 Ranger Radio Wiring Diagram
2004 Ranger Premium Radio Wiring Diagram
2004 Ranger Radio Wiring Diagram With Audiophile
2005 Ranger Radio Wiring Diagram
2005 Ranger Premium Radio Wiring Diagram
2005 Ranger Radio Wiring Diagram With Audiophile
2006 Ranger Tremor Radio Wiring Diagram
2006 Ranger Radio Wiring Diagram With Audiophile
Cooling / Air Conditioning
1996 Blower Motor Diagram
1983-1991 – Lighting:
Auxiliary Back Up Lights
High Beam Off-Road Lights
Back Up Lights
Dome / Cargo Lights 1983 – 1988 – Ranger
Dome / Cargo Lights 1984 – 1988 – Bronco II
Exterior Lights 1983 – 1989
Headlights 1983 – 1989
Headlights 1990 & Later
Instrument Panel Lights – 1983 Through 1989
Instrument Panel Lights – 1990 & On
Turn/Stop/Hazard Lights
1983-1997 – Charging:
Charging System 1991 – 1 of 2 diagrams
Charging System 1983 – 1985 1 of 2
1997 Ford Ranger Charging System
1983-1991 – Engine Controls:
2.3 Electronic Engine Controls – 1 of 3
2.3 Electronic Engine Controls – 2 of 3
2.3 Electronic Engine Controls – 3 of 3
2.9 Electronic Engine Controls – 1 of 3
2.9 Electronic Engine Controls – 2 of 3
2.9 Electronic Engine Controls – 3 of 3
3.0/4.0 Electronic Engine Controls – 1 of 3
3.0/4.0 Electronic Engine Controls – 2 of 3
3.0/4.0 Electronic Engine Controls – 3 of 3
Cruise Control 1 of 2
Cruise Control 2 of 2
1983-1991 – Ignition:
Ignition – 1990 4.0
Ignition – 1989 2.3
Ignition – 1989 2.9
Ignition – 1990 2.3
Ignition – 1990 2.9
Ignition – 1990 3.0
1983-1991 – Start / Ignition:
Starting System 1990
Start / Ignition 2.0
Start Ignition 1983 to 1988 2.3
Start / Ignition 1983 to 1988 2.8 & 2.9
1997 Ford Ranger Ignition
1983-1991 – Shift Control:
Electronic Shift Control – 1 of 2
Electronic Shift Control – 2 of 2
1983-1991 – Power Accessories:
Power Door Locks – 1989 & On
Power Door Locks – 1985 Through 1988
Power Windows
1987 – Power Distribution
1987 Ford Ranger Power Distribution 1 of 2
1987 Ford Ranger Power Distribution 2 of 2
1991 – Power Distribution:
1991 Shown 1 of 7
1991 Shown 2 of 7
1991 Shown 3 of 7
1991 Shown 4 of 7
1991 Shown 5 of 7
1991 Shown 6 of 7
1991 Shown 7 of 7
