DISCLAIMER: Activities and vehicle modifications appearing or described at The Ranger Station and it’s pages may be potentially dangerous. We do not endorse any such activity for others or recommend it to any particular person – we simply describe the experiences and opinions of other Ranger/Bronco II owners. If you choose to engage in these activities it is by your own free will and at your own risk. Any and all modifications will likely cause a vehicle to behave differently than stock. Some modifications may significantly increase your risk when driving the vehicle or be dangerous in some driving situations. Use good judgment when engaging in any activity or making any modifications. Do not take unwise risks. Consult a certified professional if you are not sure of something. The Ranger Station and the authors of these articles assume no liability for how any particular individual chooses to use the information presented here. Some of these modifications may void your vehicles warranty. Please also read our Legal notice HERE.
2019-Present Ford Ranger Tech:
If you’re looking for tech specific to the 2019-present Ford Ranger, click HERE.
Other Info:
Lift Laws:
Need to know the Lift Law for your state? CLICK HERE.
Solid Front Axle Swaps (SAS):
NOTE: Dana 44 front axle swaps are in the Axles Section.
Body Lifts:
Body Mount Replacement And Body Lift Installation
P/A #883 1998+ 3-Inch Body Lift Installation
Leveling Your Ranger – Front:
Ford Ranger Leveling Kits
Leveling Coil Installation
Factory Coil Spring Spacers
Cranking Your Torsion Bars
ProComp Torsion Key Lift
2008-2011 Ford Ranger ‘Pre-Key’ Modification
All About Torsion Key Lifts For Your ’98-’11 Ranger
VW Strut Bearing As A Coil Spring Spacer Seat
Coil Spring Spacers From Steel Washers
Rear Suspension:
Ford Ranger, Bronco II & Explorer Leaf Specs
Replacing Leaf Spring Bushings
Explorer Leaf Spring Swap / Lift
Belltech 6400 Shackle Install
Explorer – Ranger Leaf Spring Comparison
Installing Add-A-Leafs
James Duff Traction Bars
Building Custom Spring Perches
Chevy Leaf Spring Swap
Air-Lift Air Bag Installation
Rear Axle Flip
64-Inch Leafs & Shackle Flip
Rear Spring Hangers & Shackles
Leaf Spring Hanger Bracket Replacement
Spring Shackles & Hangers
Using Front Coils From Other Vehicles:
Maximum Flex For The TTB With Jeep Coils
F-150 Coils For Your V8 Ranger
Various Coil Spring Rates
Shocks:
Shocks For Your Torsion Cranked Ranger
Pick The Right Shocks
F-250 Front Shock Mount
Broken Lower Shock Mount
Shock Dimensions
Manufacturer Instructions:
SkyJacker Class I Lift
SkyJacker Class II Lift W/Radius Arms
Skyjacker Class I Instructions
Skyjacker Class II Instructions
Superlift 98-09 Instructions
TrailMaster Suspension Lift
TrailMaster Body Lift (Page 1)
TrailMaster Body Lift (Page 2)
James Duff Dual Shock Mount
James Duff Add-A-Leaf
Rancho Install Instructions
Suspensions & Lift Kits:
The Ford Ranger Front Suspension
Lifting On A Budget
1983-1997 Ford Ranger 4×4 Lift Kits
1998-2011 Ford Ranger 4×4 Lift Kits
2WD Suspension Lifts
Coil Spring Retainer
Installing Skyjacker 6-Inch Lift
James Duff 5-Inch Stage 3 Lift Install
Installing A Superlift Kit – 2001 Ford Ranger
1998-2011 Ford Ranger Coilover Conversion
Torsion Bar Codes & Part Numbers
Removal & Installation of Torsion Bar & Key
Remove Torsion Bar Without Special Tool
Replacing TTB Axle Pivot Bushings
Suspension Tuning / Wheel Travel:
Optimizing The Skyjacker Lift Kit
Getting The Most From Your TTB Suspension
Swapping From 4″ to 6″ Coils
Get More Wheel Travel
Maximizing Flex With Jeep Coils
Zimmerman Dana 35 TTB Mod For Wheeltravel
Skyjacker Extended Radius Arm Install
Chevy 64-Inch Leafs & Shackle Flip
Ford Wheelbase Chart
Suspension Repair & Fabrication:
Broken Lift Brackets
Superlift Bracket Repair
Dana 35 TTB Cut & Turn
Design Your Own Lift Brackets
Welding Brackets To The Frame
Cutting Designs In To Metal
Convert Fractions To Decimals
How To Read Welding Symbols
Fitting By Back Measuring
Bending Tubing – ProTools Instructions
4-Link Tech – Measurements & Material
Suspension Joints
SAE Bolt Torque Specifications
Miscellaneous:
SAS Front Spring Comparison
Ford Ranger Sway Bars
Monster Suspension Evolution
Exploded Views:
4X4 Front Suspension
4X4 Front Suspension (Small)
2WD Front Suspension
1998+ Front Assembly
Calculators:
Coil Spring Rate Calculator
RTI Ramp Calculator
