- Sep 22, 2007
- 7,502
- Michigan
- Ford
- Engine Type
- 2.9 V6
- Engine Size
- 177 CID
- 2WD / 4WD
- 2WD
- My credo
- A legend to the old man, a hero to the child...
05 Cobalt 2.2L Ecotec 225,000mi
Went to leave the bank this morning, fired it up it acted funny, then all of a sudden went to running real rough, "reduced engine power" came up on dash display, and was down some cylinders for sure.
Limped it 2 blocks (floored at 20mph) to my mechanic...put it on the scanner and got this code...
P0068 MAP/MAF throttle postion correlation
Now for the past month or two its had an issue where when WOT it would start missing and basically shut down at 4500-4800RPM, check engine would blink to signify a "random multiple cylinder missfire" and i noticed i went from 29-30mpg down to 25-26.
But everything else seemed fine...i was gonna throw a fuel filter in it. But didnt get around to it yet as it was only showing an EVAP code and an O2 heater code. It was throwing a cam sensor code and eveidently these cars dont have a cam sensor...its all done through the ignition module...so i replaced that and that code is gone...but the problem persisted.
Anyway my mechanic cleared the codes and it came out of limp mode but now it will not go above 3000RPM without missing. Ive parked it and am gonna put rusty back on DD duty till i figure this out cause im not driving home at 20mph from anywhere.
Anyways...you think its the MAF? Or could it be the Electronic drive by wire throttle? It has a sensor on the pedal as well as the sensor driven motor on the TB itself.
I have very little experence with this newer shit.
