1354e rebuild: How to get the oil pump off?
skrape
Denver
My '97 Ranger was making a violent "clunk" when descending against compression in 4Low. I've since learned that that's probably caused by the little plastic bushings on one of the shift selectors wearing or disintegrating... We'll see.
Anyway, local junkyard yielded a 1354 electric shift that I'm rebuilding for a swap, using parts from http://www.americanpowertrainwarehouse.com, whom I can recommend wholeheartedly.
I'll post pictures when I'm done.
I couldn't find much by way of manuals for the 1354e, but it turns out to be quite simple, with one exception:
How do you get the oil pump off the main shaft? There's no snap ring - looks like a convex ring of some sort. Should I just apply some muscle and press that off the main shaft?
skrape
Denver
I figured it out, and its so simple it makes me feel stupid.
There's a slot in the oil pump, and that slot engages a roll pin on the main shaft. Turn the oil pump on the shaft until the pin is visible, then the pump slides right off.
You can see the slot on the product pic at this vendor's site:
http://www.americanpowertrainwarehouse.com/bw1354-transfer-case-aluminum-pump-assembly-fits-bronco-ii-ranger-explorer-mazda-b-trucks-86-05-4400-508-001/
Let me see if I can link to the image directly:
See the slot? Turn that till you can see a roll pin, then the pump slides right off the shaft.
Good thing I didn't try to press it off the shaft - that would have been messy. :beer:
