1984 ranger 2.8l fuel not getting to carb
superj
2,578
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
i have also run an electric holley pump and holley adjustable regulator in the engine bay to fuel my wrangler v8 swap and on my 80 bmw when i converted from mechanic fuel injection to a weber 32/36. with no in tank pump, both times the holley worked great.
bubba79
4
26143
2.8 V6
171..+0.30over
4+4 susp.and body
12.50x16 agg.tries about 33"
You could also do away with stock tank and run a fuel cell in the bed with the mechanical fuel pump that is how I have mine
Angry Possum
No Fat Chicks, Truck Will Scrape
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
Sometimes you eat the bear, sometimes the bear eats you.
I put an electric fuel pump in my 1985 Boat engine. It's a Chevy 3.0L with a carb. It works great. My mechanical pump shit the bed so I tried this one shown
Worse comes to worse, You can hook it into your gas line and temporarily troubleshoot possible fuel pressure issues at least.
I wonder what fuel pressure your system requires. You can also test your fuel pressure perhaps prior.
CarBole Micro Electric Gasoline Fuel Pump Universal 5/16 inch Inlet and Outlet 12V 1-2A 35GPH 4-7 P.S.I. https://a.co/d/aTQg432
8,370
35GPH(gallons per hour) can support up to 300HP Carb engine
Carb float bowl valves are OK up to 10psi
Angry Possum
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
That pump I posted would do it. I'd probably go electric too in this posters case. No brainer for $22.
