1986 Ford Bronco II no crank no start
LucasW7926
New Hampshire
Ford Bronco II
My uncle's 2.9L auto bronco randomly stopped starting for him. I looked at the starter and noticed there was a cable that had broken off above the starter, on the transmission. I'll be able to get better photos this weekend when I get out there, but was wondering if anyone knew what this cable could be and if its the source of the no crank. I'll try jumping the solenoid too when I'm there. There is fuel and spark.
LucasW7926
New Hampshire
Ford Bronco II
I'll also pull out the broken piece of the connector so we can see what the plug looks like.
alwaysFlOoReD
5,098
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
That doesn't look like a transmission to me that looks like the engine block. So that particular sensor, I believe, is an oil level sensor. It may be a knock sensor.
rusty ol ranger
2.9 Mafia-Don
7,502
Michigan
177 CID
Knock sensor.
Wouldnt keep it from cranking or starting.
LucasW7926
New Hampshire
Ford Bronco II
Thanks, it definitely does look like the knock sensor I'll get to look into it more either this weekend or next...any ideas what else could cause no crank no start? My main guess is the solenoid as it looked fairly rusty and there was no noise from it when I tried turning it over.
rusty ol ranger
2.9 Mafia-Don
7,502
Michigan
177 CID
Its possible.
You can take a big channel lock and "jump" the solenoid from one big post to the other. That will tell you if it is bad
alwaysFlOoReD
5,098
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Its possible.
I never thought of using channel locks like that. I'll remember that.
