1992 Ford Ranger 2.3 Lima Turbo
Rangerdude
Greensboro
Hey, I have a 1992 Ford Ranger 2.3l with a 5 speed trans.
I was wondering if I should do a turbo with stock internals or if need be what parts I should upgrade or if I have to buy a already turbo built motor? I will take power specs as they come and don't plan to do any more than 8lbs of boost. Any help will be appreciated.
Thanks,
Rangerdude
scotts90ranger
4,372
Dayton Oregon
2.3 Turbo
The stock pistons likely won't take any more than 5psi reliably, stock injectors can't really support any more than stock power. The rest of the bottom end is the same as the turbo engines and can handle like 300hp... forged pistons are a bit spendy but out there... The transmission should be good, mine's been holding up fine, I upgraded the clutch to a Centerforce though...
Unless you can find a stock turbo engine and computer I'd probably go stand alone for fuel control...
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Consensus has it that stock guts are good for 4-5lbs at best before things get hairy. 5lbs *should* grant you 35% more power.. or there abouts..
Rangerdude
Greensboro
Thank you for responding,
I would like to also know if taking the oil pan off and removing the pistons through the bottom of the engine and push the new pistons through the bottom would work and whether or not I should change out the valve springs while I am at it.
Thanks,
Rangerdude
sgtsandman
Aircraft Fuel Tank Diver
12,651
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Thanks,
Rangerdude
The only way I’ve ever seen pistons installed is from the top.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
use that to base your build from....
you can backyard razorblade these for about 1400 yourself and go to a megasquirt type setup which with injectors will be at least 1 k and do really well.
finding a complete running donor is the only easy way to do it....they are out there....
Rangerdude
Greensboro
Good afternoon,
Do you all also know whether or not I could tune the engine on the road myself? Also, have you all heard about any break in periods for new pistons and springs?
Thanks,
Rangerdude
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
with a ms3....your better off learning with the engine naturally aspirated....get it running well....
from there stepping up to boost will be less destructive.
thing about boost....you can have the best of the best dial in your powertrain....10 minutes later some minor unknowable failure can lean ya out wot and your toast.
but if you have to ask....you need to read.
Rangerdude
Greensboro
Good afternoon,
Thanks,
Rangerdude
And by chance can you all guide me on how to do my exhaust header. Would I use a mustang header or fab my own?
Thanks,
Rangerdude
Rangerdude
Greensboro
I see what you mean, I will give it a shot if I can.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
