1994 Ford Explorer dash in 1988 ranger
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Sad day. I always wanted a 2 dr Explorer. sniff sniff. Looking good BTW.
rocketkart
32
Florida
Ford ranger
Decided to put the 4 inch suspension lift kit on this weekend. Definitely looks good. Think it more like 6 inches but with everything off I’m shore it will drop back down with everything back on
Junk Collector
Truck of Month
4,802
Rapid City SD
Looks good! Should have swapped the newer style cowl over while you had it apart - leaves and stuff falling through the slots I think is what causes a lot of rust issues on these.
rocketkart
32
Florida
Ford ranger
I was actually considering that but really didn’t want to open another can of worms.
rocketkart
32
Florida
Ford ranger
So I ordered a set of headers that say it fits the 2.9 but from what I have read the 2.9 and 4.0 are the same so I’m hoping they will fit good without to much Modifications
rocketkart
32
Florida
Ford ranger
So today I wanted to try and swap the auto locking hubs on the 1994 Ford explore onto a 1988 Ford ranger but there not the same. The spindles on the explorer are bigger than the Ranger. Dose anyone make auto locking hubs for the 1988 ranger ?
Junk Collector
Truck of Month
4,802
Rapid City SD
Ford made auto locking hubs for both Dana 28 (83-89 trucks) and Dana 35s (90-97.). Not much will swap between those two axles as they are quite different but similar enough. I would advise you not to use auto hubs, they are not very reliable, but if you do then you could either swap the entire front axle from your donor or find a pair of hubs in the junkyard from a 83-89 ranger or bronco 2.
rocketkart
32
Florida
Ford ranger
The only reason why I wanna go with the auto hubs is because the new rims that I have have caps that cover the locking hubs so auto locking would be nice but not necessary
rocketkart
32
Florida
Ford ranger
Got my intake and valve covers cleaned up and painted today as well as new injectors installed. Have the heads at the shop getting seated valves and valve seals done. Slowly getting there.
rocketkart
32
Florida
Ford ranger
Anyone know where to get new vavle covers from ? The one I have are rusted in the corners and are in bad shape. May have to take a trip to the junk yard but would really like new ones. Thanks.
rocketkart
32
Florida
Ford ranger
been a while but getting her painted.
RobbieD
2.9l Mafia
3,466
Georgia
Looking good. Nice paint.
