1998 ABS
Bolo4u
7
NorCal
I started my upper/lower control arm and new Code 1 torsion bar install and upgrade. I also found someone local selling two new Motorcraft 4x4 hubs (with seals and snap ring retainer) from a 1998 he no longer owns so I bought those and will be installing those as well. Well, I ran into an issue. The hubs he had have the ABS wiring, but it turns out my old hubs do not have ABS. HOWEVER, I do have the ABS module in the engine compartment and empty plugs (which I believe are the ABS harness connections) on the driver and passenger side. I don't know if at some point prior to my ownership non ABS hubs were installed, even though it's set up for ABS, or what may have happened along the way.
So my question, since I have the ABS module and available plugs, am I good to simply route the wiring and connect, or do I need to do anything extra to make everything work?? Thanks in advance.
Bolo4u
7
NorCal
8,370
If you have the 5 brake line ABS module in the engine bay then it should have the two front ABS sensor connections
But if they have been disconnected then you should have had the yellow ABS Light on the dash on this whole time, or bulb is burned out
If you are asking if the 4 wheel ABS module works, there is no way of telling until you try it
Yes, there could have been a reason previous owner disconnected it, but wouldn't be because he couldn't get ABS front hubs, I don't think you can get these without ABS sensors
Bolo4u
7
NorCal
Thank you for the reply. I looked and I do have the rear axle ABS sensor (module on top of the differential?). The only thing I see that is likely abs related is bolted to the driver side inner fender between the battery and fuse block. This isn't my picture but I found it on TRS.
There is a two wire connector, with plug protector connected to the wiring harness next to the module, and another similar plug on the passenger side engine compartment near the fluid reservoirs. I don't have any ABS warning lights on the instrument cluster, but don't know if the bulb is out or even present.
The ABS sensor wires coming from the hubs are each 6-8" to short to reach the plugs mentioned above. Ill likely just zip-tie them out of the way.
Apparently hubs for these were sold without ABS, because the ones I pulled off, do not have ABS harnesses or holes where they might connect.
Edit: I followed the link to the thread where I got the picture below. Apparently I too only have rear wheel ABS, not front. would I cut the harness or do what I planned, zip tie it?
8,370
Yes, that's a Rear ABS system, looks like this one: https://cimg3.ibsrv.net/gimg/www.ranger-forums.com-vbulletin/652x531/rabs_valve_complete_b37fbf7181e49e3b5ff985be7f8fe55744c042f1.jpg
4WABS unit looks like this: https://www.ranger-forums.com/attachments/suspension-tech-36/88195d1501269039-4-wheel-abs-2-wheel-abs-img00115-20110226-1819.jpg
5 brake lines
Yes, just zip tie the front hub sensor wires out of the way
Yellow ABS light on the dash should come on with Key On, then go off after a few seconds, that's a "Bulb Test", all warning lights or indicator lights on the dash should come on for this "bulb test"
Not a system test, just a bulb test
