1998 & Newer specific Ranger problems.....
49
Huntington Beach
XLT 4 x 4
235/75 R15
Life is just a long string of stories.
Cab light sticks on oil your door latches and pivots.....get a oil squirter from ACE and get full synthetic 10w 20 or 5w 20 and use that.......but yes wiring on these damn +1998 trucks sucks.....and trans is meh......I has the 3.0l with the 4 speed auto.....I think its the fully electronic 4 speed auto cuz I forgot the technical name....my heater that I rarely use in Florida never seems to cause any problems.....
1999 Ranger XLT Supercab, 4 X 4, LSD 3.73 diff, tow package, automatic. 264, 077 miles. Showroom stock.
I shouldn't say this ... kiss of death ... Everything works A/C, Stereo (tape and CD and radio). Only had to replace the front lockers with manual locks.
Sprayed WD-40 in the door catch and cured the dome light issue (switch was sticking),
Craig0320
225
Mississppi
Break it right the first time. Fix it better the next time.
Everything normal here. I experience all the same items.
07nhbpsi
17
Monroe mi
Really? I cleaned it several times since the last oiling. I noticed an increase in performance when I first installed the K&N, but after the oiling, I started having problems. Maybe I'll chance the MAFS and see what happens. Do I need to disconnect the battery and re-boot after replacing the MAFS, or should the new one start sending correct info to the computer?
Well, any problems u inquire from a K&n filter, happen from over oiling the filter
unclekenny
Branchville, NJ
2011 4.0 4x4 bought new. 140,000 miles Half of that towing 2000 lb. trailer. No off road.
1 set brakes.
Replaced left front hub
Replaced corroded and leaking transmission line
Replaced leaking rear diff cover.
If you raise or lower both windows at the same time it blows the fuse.
My only gripe is that it is hard to read the instrument panel in the daytime.
Has been a great vehicle.
Blue_Bunny72
West Bend Wisconsin
Ford Ranger XLT
On my "98 3.0, I've had plenty of issues.
-4x4 won't engage (some sort of motor blown in the TC)
-3.0 has some MINTY rod knock
-Burns lots of coolant
-Gone through multiple alternators
-Water pump cracked and was pissing coolant
-Dash lights always burn out
-Positive camber on the front wheels
-Rear shackles rust through and send leaf springs through the bed
I've had my fair share of issues that seem pretty common on 98+ rangers above 120K. Hope this helped out!
ret_Marine2003
Law Enforcement
4
The crotch of the mitten
Ford Ranger XLT
2.5 (4 Cylinder)
Stock
Stock
No greater friend, no worse enemy...
I have a 1998 Regular Cab XLT Stepside
2WD 2.5L 5spd standard trans.
It has a leaky and noisy Power Steering problem.
Cab floor rust out from water leaking inside.
james 53
24333
ford ranger
I'm curious, and it would be easier to ask then to read every post in this forum.....
What are some of the problems encountered in the 1998 and newer Rangers that are specific to those models? As the tech library expands, I'm trying to figure out what direction we need to go now that the 1998 and up Rangers are becoming more common and being modified more.
Whether it be hubs, axles, transmissions, engines, electronics, etc.....please post any problems you see popping up with these trucks that we may need to address in some tech pages.
It would seem to me that there would be more and more electrical related issues.
You may post some that I already know about or have addressed elsewhere, but throw anything you can think of out there. Who knows, we may find that a specific problem is more common that you think.
Thanks.:headbang:
rough idle,changed iac egr egr solinoid maf vac lines intake fuel pump checked vent system and gas cap,comp 155 155 155 145 155 155,new o2 sensors no catalyst problem -no codes?can u help it and me or should i shoot it?
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Theres a sub-forum for whatever motor you have in your truck, you should make a new post there asking for help, I'm sure you'll get advice. Lots of folks here are extremely knowledgeable.
james 53
24333
ford ranger
2001 4.0l 4wd
sgtsandman
Aircraft Fuel Tank Diver
12,651
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
@james 53 I think you missed the point in blmkn’s reply. This is a general what’s is recurringly going bad in Rangers of this year span thread. Not a “I have such and such problem with my truck, can you please help” thread. Since you have a 2001 4.0, please make a thread asking your questions in the engines section under 4.0 engines.
It helps isolate your issues into one thread to go back to and isolates it to a particular engine for other members in the future that might need help. Posting here is liable to get your responses lost in amongst other thread comments not related to your issue.
And welcome to the forum. We want to help and make it easy for us and you as you work through your issue. Help us help you.
RHouse
Raeford , NC
Ranger Edge
Have 2002 Ranger Edge 2WD with 118k:
-Replaced upper control arms
-Replaced Cam Sensor and Synchro
-Center console loose at hinge (see where previous owner tried to fix)
-PCV rubber elbow at rear of motor looks cracked but I don't want to mess with it until ready to replace the PCV assembly
Overall very happy with vehicle
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
If you ask me there is 4 generations of Rangers. '83-'92, 93-97, 98-11, 2019-up
Fredness
28
Sasquatch Country!
Ford Sport Trac
4.0L SOHC
Break open the connector underneath the Driver's Seat - clean it with Electrical Contact Cleaner and then use a bunch of Di-Electric Grease when putting it back together.
If you do this every couple years, it will last forever.
Or buy a used 2001 from Minnesota that was never cared for and have to splice all the wires together because the corrosion was so bad...
1999Mazda Central Florida
10
Mazda
Michelin LTX M/S P235-75R15
Here's the wiring bundle diagram for the electronic trans.
akdsrtrat
Phoenix
Ranger XLT 4X
The only thing I can think to add to wvcat's post is the typical driveshaft thud/clunk when starting to accelerate and when coming to a stop.
Just lubed the slip joint on my 98 and what a wonderful change!
