1998 ranger help
madeforspeed
I have a 98 ranger 3.0 5speed it blew up and I was goin to put a 97 4.0 out of explore in it what do I have to change can I use trans and clutch and flywheel?
swynx
9
lewiston idaho
Mazda
although they use the same transmission the holes are different. you need the 4.0 engine, computer, wiring harness, the 4.0 transmission, idk about the motor mounts. youd be better off doing a 5.0 swap, as its just as much work. or buy a truck with a 4.0
cp2295
7
Washougal, wa
4.0L swap, 8.8 explorer axle, IFS front end
If you ain't first you're last
Yeah I did the 3.0 to 4.0 swap and I wish I swapped a 5.0, however it was easier to me than the 5.0 because I wanted a manual 4x4 which would have been alot more difficult I believe than the 4.0 manual swap.
I can tell you all I had to do if you're interested
