1999 explorer v8 into a 1994 Mazda
EmmaEatUraz
New jersey
Ford ranger
So I'm planning on swapping a 302 from a 99 explorer into a 94 Mazda b2500. Paired with a manual transmission from a f150 (m5od-r2) ik there's a tech page with swaps but I didn't think it would hurt to ask for advice or tips
JoshT
1,734
Macon/Fort Valley, GA
mI'll tell you the same thing I said the betch102 about his. I'd use the explorer engine and acessories. I'd use a fox mustang EFI system. That EFI system will be a lot easier to get installed and working in the older truck.
If you want to save money by using the Explorer system, look for EFIGuy on Classic Broncos forum. He's got a whole set of articles and videos on making the Explorer EFI work standalone, or without the rest of the explorer. This will also require getting a tune for the Explorer motor to delete the PATS system, or figuring out how to graft it in and stash the PATS module, transponder, and key somewhere in the truck. For the fuel system the Mazda uses a fuel return line, the Explorer does not. The mazda runs at 45 psi fuel pressure, the Explorer runs at 60 PSI fuel pressure. You will need to upgrade the fuel pump to provide enough fuel pressure and install an inline regulator to set and control it, with return fuel going back to the tank.
I'm not sure what the tech library article says about engine mounts. Some swaps use mustang mounts or swap mounts. A lot of the old swap mounts are no longer available. There is a better option than both. Check out Rickz Rangers. He makes a motor mount plate to adapt the 5.0L to 4.0L engine mounts. The 4.0L mounts are cheap, available, and plenty strong enough for most 5.0Ls. There are also instructions for DIYing them, but IMO it's worth the price to buy unless you have the materials and tools lying around.
EmmaEatUraz
New jersey
Ford ranger
Would it be easier to gut most of the truck out and swap in most of the explorer parts? i.e take the fuel tank from the explorer since i already have it. Also whats notoriously hard about using the explorer EFI compared to the mustang?
97splashdaddy
18
Fl
Ford ranger
To all the veterans around here. I know it gets old answering the same questions over and over. Just know your opinions are new to alot of us and very much appreciated. Thanks from the back corner.
JoshT
1,734
That sounds like you are considering the same path that betch was talking about and that I've tried once before. Attempting to swap in as much of the Explorer parts and wiring as possible. If the Ranger is mostly intact, I would not do that. You are just asking for too much trouble and work to replace things that are perfectly functioning. Read the posts in that other thread to find out more about my thoughts on that, I'm not going to retype it when the other is still on the first page of this section.
The Explorer tank probably won't fit the Ranger right, the frames and floors are pretty different. Even if it did, you'd have to run custom fuel lines.You could possibly take the fuel pump itself out of the Explorer and install on the Ranger sending unit,other than that I think I roughly covered connecting the fuel in my last post.
Explorer vs Mustang EFI...
What makes the Explorer hard is complexity. That EFI system is a lot more integrated into the body harness and other systems on the truck. If we're talking about the PCM itself the Explorer uses a 104 pin ECU for control, the mustang uses a 60 pin ECU. That means potential for an additional 44 circuits to make the Explorer run and a bunch of those are used. Also the Explorer EFI system has a 42 pin connector between it and the chassis harness, and most of those connectons are used to pass some signal or data. The Mustang EFI system on the other hand ios practically a standalone system from the factory. It only needs a few wires to make it run, really not much more than a carbureted engine I think, and maybe a few extra connections for gauges and warning lights but they aren't necessary. Heck the Mustang might use the same style ECU as your truck, so once you find the right wires, you might be able to connect to the same locations as what you are removing.
One of those conections into the body harness is the previously mentioned PATS system. The tech articles pretty well cover how to overcome that, but the Mustang EFI doesn't have to deal with it at all.
It may not matter since you are going manual transmission, but the 99 Explorer gets it's vehicle speed information from a sensor in the rear axle after it passes through the ABS box. You won't have either the sensor or the abs module. The sensor would be easy to get with an axle swap, but you do not want to try retrofitting the Explorer's ABS. My understanding is that both are required because the signal from the axle gets modified by the ABS module. Might not matter since you are going manual, I don't know if that signal affects the engine, or just automatic transmission shifting. Mustang EFI needs none of this, it just runs off engine speeds.
Mustang manual transmission ECUs are fairly common. Explorer manual transmission ECUs are nonexistant for the 5.0L and will require tuning to remove it.
Upgrade parts that work with the Mustang EFI are much more common. Tuners that work with the Mustangs also seem to be more common than for the explorer.
There are probably some other things I wanted to say, but I'm getting a headache and can't remember them right now. Also need to go get the shed closed up before it gets dark.
JoshT
1,734
I don't mind answering repeated questions posted in the right forum section. I'd like to thank @EmmaEatUraz for taking the time to do that when so many don't.
I don't really do quick replies. They tend to be long and elaborate (and often not understood). I'm just not going to type out the same response when the threads are that close together. It's much easier for me to just direct them to read the other thread.
EmmaEatUraz
New jersey
Ford ranger
Thank you so much for the input honestly. I will be documenting my work once i actually begin. Currently just been researching for the past 2 weeks with this explorer sitting in the street.
19Walt93
4,467
Canaan,NH
351
3"
235/55R16
Your 94 has EEC IV and a 99 would have OBD II/EEC V which controls a lot more functions. I agree that using 95 or earlier Mustang harness and processor will make the project easier. The EEC IV processor controlled only the engine and automatic transmission while an EEC V PCM handles a lot of other functions that you won't need.
No members online now.
