1st gen TDI ranger, prerunner style build.
powerstrokekid
111
New London, Ohio
Solid Axle Swap 4x4
I took the ranger to southington. It continues to impress me, I can’t wait to start on this tdi swap because the truck is slow, and is burning a lot of oil. It was loading up bad idling around. I ordered door panels, I think the only other thing I’m gonna buy for now is new door seals then I’ll start saving for the tdi adapter!
powerstrokekid
111
New London, Ohio
Solid Axle Swap 4x4
Gonna drive the ranger to work tomorrow, so glad to finally have a ranger after all these years.
powerstrokekid
111
New London, Ohio
Solid Axle Swap 4x4
So I have always wanted aluminum door panels in a first or second gen body style and thankfully someone on the internet sells them! LRB speed. They came with m5 rivnuts and hardware but I didn’t have that size die. I used 1/4” rivnuts and stainless bolts/washers.
Before closing up the doors I sprayed fluid film down inside since it’s rust free and I’ll be driving in the salt.
I added the middle bolt on the back edge of the doors. I felt it held it down better. Other than that they fit perfectly!
powerstrokekid
111
New London, Ohio
Solid Axle Swap 4x4
I thought a blew a radiator hose, after all they’re at least 20 years old if not original? So I replaced all hoses.
Started it and idled, no leaks. then after it started to get warm it opened up a crack in the radiator 😬
Dantheman1540
464
Florida
There are some really nice large all aluminum radiators out there these days. I think I paid $240 for mine and it came with an E fan. It works so good I can rarely get the truck to heat up to the N in normal
Bgunner
1,085
Western Mass.
Ford/Ranger XLT
225/70/R15
Seeing how you did the door panels made me think of how nice a set of the seats from an old Astro I had would go in that cab. They had arm rests on both sides that were both foldable.
