2001 4.2 f150 cutting out
DFracing
it was originally shuddering upon accel, but once it got above 2k rpms it would go no problem, i put a new coil in it, and cleaned the maf, and air temp sensors. it fixed the issue for about 2 days, now the truck will idle but will not move under load, give it gas even in neutral and it cuts out and dies. Took replacement coil off and put a warrantied item on, same issue. did i ruin the MAF when i cleaned it, or did the new coil blow my plugs and wires. or?
alwaysFlOoReD
5,096
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I've had a similar problem with my 2.9. I have a bad injector but don't know if thats the only problem. I put in some fuel injector cleaner for the last two fills and the problem has been going away. Fingers crossed that is my cure.
Richard
DFracing
the problem is it is not even driveable dies when the throttle is applied even just a little bit. but it idles no problem
