2003 ford rannger 4.0 sohc coolant
garywbarton
West virginia
ford ranger
hello folks i have a 2003 ford ranger 4.0 sohc engine that looses coolant i notice some steam at exhaust sometimes but not all the time mostly when you decelerate from off highway and pull out again ...i figure if its a cracked head or blown gasket it would be there all the time... no coolant in the oil any help is appreciated ...thank you
don4331
1,346
Calgary, AB
5.3
Simplest way to confirm blown gasket - with engine cold, open radiator, start engine and watch for bubbles in radiator fluid. I think it works for cracked head too.
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Air bubbles...
Google cooling system glove test... if there is a gasket or head issue... it will blow the glove up.
A blown head gasket situation would likely say the engine was overheated at some point. Was it?
The plastic thermostat housing is known to crack and create a slow leak. How much coolant are you going through?
I'm also moving your post to the 4.0L forum...
