2005 blend door good actuator not working
tghsmith
north carolina
ford ranger
original owner 2005 edge, heat control stopped working overnight.. blend door is good- tried new blend door actuator it will not move also,, replaced center hvac control unit (hot-cold knob) did read dc power at actuator connector,, checked all wires, fuses and connectors that could be reached,, getting frustrated,, using an actuator part rigged a push pull rod to get either heat or ac. so the truck is drivable (it is been my daily driver,)
tghsmith
north carolina
ford ranger
replaced the 3 wires that run from the hot/cold knob to the blend door actuator with wires running behind the radio area,, must have been a bad wire because it's working!!!
No members online now.
