franklin2
- Dec 24, 2019
- 1,771
- Virginia
- Bronco II
Eyeball it under there and see what is in the way. On a 1980-up truck, it's a miserable job and you have to reach up over the pan and unbolt the oil pump pickup tube. Maybe you have more room and your sump will be up front so it might be easier.77 LTD II.
No engine is not out. Im thinking of just slapping the chain in fireing it up and seeing where im at. If i pull it chances are its getting rebuilt regardless.
If i can pull the pan with it basically in ill do it...but if i gotta pull it anyways...
