bobbywalter
TRS Technical Staff
Ugly Truck of Month
- Aug 9, 2007
- 4,668
- woodhaven mi
- FORD mostly
- Engine Type
- V8
- Engine Size
- BIGGER
- 2WD / 4WD
- 4WD
- Total Lift
- sawzall?
- Tire Size
- 33-44
- My credo
- it is easier to fix and understand than "her"
cam guy will send you the break in additive. follow procedure and you will be fine. just go conservative with the carb so it starts and runs fine for break in...sometimes a guy cant keep it running smooth and that with tear it up.
generally speaking i move any v8 swap over in 4x4 applicatons using a fullsize t case because its a fullsize t case.
its easy to fab up an airbox duct so you still have your heater/defrost functions. even ac if you rob a burb or van unit. from the pictures, your chosen mounting method appears it may allow stock ac primary box and evaporator to be retained with a custom engine side shell like i do with 351's.
if your not afraid to put the radiator forward into a modded grille and frame you will have enough room for a mechanical or killer electric fan as well....and plenty of radiator to mitigate cooling issues.
there was a ranger on e bay a few times with the lower pump package like you have available based out of texas with similar setup...
i would likely prefer an over/outside rail steering box myself to make for some room for filter etc but if you can make it go with a stock box its gonna save some time on initial setup.
one thing i strongly suggest is to take 20 minutes to get rid of the radius arm bracket rivets and put bolts in there so the radius arm brackets just pop out for future work. that and a removable core really make maintenance a breeze.
