4x4 Front Hub O-Ring
17,848
SW Iowa
c094728
Colorado
Ford/Ranger
I tried the Napa part # 727-2153 for my 88 ranger manual hubs but they were at least an inch to large
17,848
SW Iowa
Older trucks use a smaller o-ring:
The correct size for the factor hub o rings on the 1980-91 rangers is 3.109" I.D., 3.387"O.D this is the oring standard AS568-235. These can be purchased from Grainger in a pack of 10. Item #: 41UM71
fixizin
FoMoCo is forcing me to buy a 'yota
114
Ft. Lauderdale, FL
XL Spurt
3.0 (Flex)
A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
OK, this entire most-excellent thread has covered the O-ring on the backside of the hub... should we start a separate thread for Duh PVH hubs, which also have a smaller O-ring (approx. 2.65" dia) on the front side, which actually gets covered by the PVH hub itself, and maintains vacuum in the main "cylinder" of the PVH mechanism... ???
fixizin
114
Ft. Lauderdale, FL
XL Spurt
3.0 (Flex)
Hello, is this thing ON?? :icon_confused:
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
What’s your question? If you want a separate thread, go ahead and start one. Thats the only question I see you asking. So there isn't really anything in your post for people to comment on unless Dirtman’s butt itches.
Regarding the PVH hubs, it seems to me that they are generally regarded as unreliable and most people convert to live axle or some other style hub.
tlthehun
Grrr, I just went with the first post as it came up as a preview in Google search.
'89 Ranger, V6, Dana 28, manual hubs. The NAPA 727-2153 is too large for me, too, as explained above.
Thanks for pointing me to the correct one.
Shack_302
Bear, DE
Ford Ranger XLT
Been looking for that replacement o ring today and yesterday. Ford dealership can't even get me it. Any chance you'd know where to find it?
I found this kit on eBay that includes the ring and its part # ( F87A-3N320-BA ). https://www.ebay.com/itm/97-03-Ranger-96-01-Explorer-OEM-Ford-Pulse-Vacuum-4x4-Front-Locking-Hub/172428789337. But they don't sell it separately and neither does anywhere else. Nothing comes up when that part # is entered into google. Any help would be greatly appreciated and if I won't be able to fine one, any advice on what to use in replacement of that seal.
Also found this o ring on rock auto and it seems it measures to be the same or very close to the ring I have but says for rear hub.
2.22 ID X 2.287 OD X 0.067 Thick; Hub to Hub Lock
fixizin
114
Ft. Lauderdale, FL
XL Spurt
3.0 (Flex)
FYI: the backside 3.50" I.D. x 3/32" thick O-Ring that is the subject of this thread is sized for a stretched-tight fit! i.e. the "land" (not groove) diameter is 3.94"... the groove DEPTH is about 0.06, so that's about 3.82" groove dia. = 0.32" undersize on the O-ring, or 0.16" radius undersize, but hey, I used them, and it seems to work... gotta use similar factors on sizing the FRONTside O-ring.
ericbphoto
16,598
Wellford, SC
6"
There is more than one size. There are different hub sizes.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Junk Collector
Truck of Month
4,802
Rapid City SD
I found these O rings at a local hydraulic shop for about a buck each. I think they are the same or close to the same size the was mentioned earlier in this thread. They are just barely a stretch fit...they are about as tight as the others I've seen.
These are for a Dana 35 application, '90 and newer, I am going to try and round up some smaller ones that will fit Dana 28 axles and get a part number/size
75088
ford4wd08
510
Alcoa, TN
2.8 V6
I did get around the installing the o rings I ordered from info on this thread for my Dana 28 when I put my new wheels on. They fit great. My old ones were flat. It was time.
Junk Collector
Truck of Month
4,802
Rapid City SD
FYI there is a second smaller O ring that seals the outside of the hub as well and it requires the hub to be disassembled. I have not seen those go bad before. The big ones, are almost always just simply missing.
