- Sep 6, 2013
- 1,346
- Calgary, AB
- Ford
- Engine Type
- V8
- Engine Size
- 5.3
Cute?
Travelaire W186:
Hitch weight 639 lbs, 5th wheel hitch 165lbs = 804lbs total Payload capacity of 1,350lbs - lots left for driver and passenger
Trailer weight 2,875lbs, B4000 has auto and 4.10 gears = GCWR 9,500 lbs, which in theory it allows 5,560 lbs of trailer, even subtracting driver, passenger and hitch, I'd still have 5k lbs available! So, lots left.
7' wide x 8' tall = 56ft^2 of front area; brochure says 50 ft^2 max as consideration and exceeding may reduce performance of the towing vehicle.
Working on securing the hitch and installing brake controller. I should be able to let you know how it tows in May.
If the clone doesn't work out; I have the F-150. But it might not notice it is towing anything.
Travelaire W186:
Note, same brochure says 60ft^2 for SuperDuty which would be 8' wide by 7.5' tall and you would be hard pressed to buy a 5th wheel that small (a lot are closing on 100ft^2), so I'm thinking soft limit.
So, I might not be able to drive 120km/h on the interstate; not that critical, speed limit is 110 up here anyways.
