- May 18, 2008
- 368
- Vancouver area BC Canada
- 92 & 83 project
- Ford
- Engine Type
- V8
- Engine Size
- 4.0L 302
Been slowly chewing away at this as time allows... work has been busy and tired after work to get out and do stuff...
but slowly doing the last of the wiring and all the small stuff that doesn't make any pictures.... BUT.... here is the cab one step closer... seats in and console finished. wired up and ready to go.
changed the wiring a bit from before. there are 2 REM switches, 1for the power amp and 1 for the radio. then a separate wired in set of plugs for charging phones and stuff instead of the cig lighter, wired direct.
still need to wire in the fuel pump and finish off the fans get back brakes done and to the shop for a new drive shaft measured up.
cheers
cheers
