RyanL
- Apr 6, 2011
- 0
- '89
- Ford
- Engine Size
- 2.9L
The ground that I think that you're talking about bolts to the rear of the passenger side head and goes up to the firewall right above it. Are you saying that it is not connected? Before you rule out a bad ECU, check all of your important connections and your grounds (clean them all up and reconnect them). Make sure that you have power going to your ECU with the ignition switch turned on. Maybe it's as simple as a bad relay or blown fuse.Another thing I found is something that looks like a ground strap maybe? It is hooked to the body of the truck towards the back side of the passenger side front wheel well kinda right around the bellhousing of the tranny. Could someone look at their truck and tell me if they have this same thing and where it goes?
