RobbieD
2.9l Mafia
- Aug 6, 2007
- 3,465
- Georgia
- Ford
- 2WD / 4WD
- 2WD
- My credo
- Toonces drives a Ranger . . . . just not very well.
Does it look like this:On the drivers side of the engine harness, there is a male grey 8 pin plug with that red/green wire. Should that be spliced into the column wiring?
If so that's C102 and you can get ignition power there.
edit add: BUT you will have to test the Red/Lt Green for both switch positions: "Run" and "Start". It may be only "run", and a second wire will be start, and you also have to check for, and deal with, the inline resistor if it's present.
