94 Ranger - Largest spare tire size for under bed spare carrier.
jschner
Arizona
I have a 94 Ext Cab 4.0 4x4 with stock suspension and 31s on 15" rims. I need to buy a new spare tire and tired of it riding in the back of my bed. The AZ sun is not kind to the spare either. What is the largest spare tire size that will still fit in the under bed spare carrier? Mine is the bolt and swing arm style carrier.
17,851
SW Iowa
I tried a 31 under my '85 and was a hard no-go.
I am not sure when if ever they changed the carrier until they went to the cable style.
Junk Collector
Truck of Month
4,802
Rapid City SD
235-75-15 is a pretty safe bet especially on a 3rd gen.
First gen trucks were hit or miss, my '88 won't fit anything bigger than a 215-75-15. I found a spare tire carrier from a 2nd gen that a 235 fits in though and it was a direct bolt in on a 1st gen frame.
I will confirm that a 31" tire will not fit there regardless, I tried and it will simply not fit with stock parts. If you built your own cradle, it may work, that size tire does physically fit between the frame rails but it's the cradle and the rear crossmember that don't allow it to fold up into place.
SenorNoob
569
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Soo, cable style swap for OP?
sgtsandman
Aircraft Fuel Tank Diver
12,651
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
17,851
SW Iowa
Mine would have worked but the passenger side of the tube had a dogleg in it, likely for the original exhaust that screwed me up.
Josh B
1,986
Oklahoma
If it's the metal cage type rack a 15in. Goodyear wrangler can be a tight fit.
If you have a flat on the back axle you have an access problem
I have a 93 Supercab with a toolbox and opted to just keep it in the bed.
There is also a fair size rack out there I can easy lift the box and leave it chained to the rack if I need to do some moving/hauling
The spare is chained to the bed on the driver side
Best option I came up with
Bgunner
1,085
Western Mass.
Ford/Ranger XLT
225/70/R15
The owners manual for my '94 says that "A full size spare may break the hanger". This boggled my mind as mine came with 14" rims and had a full sized spare. A 225/75/14. Maybe they were referring to the 15" rim but who knows what they thought at the time.
gw33gp
536
Costa Mesa, CA
4.0 SOHC
33"
My 02 easily fits a 31x10.5" tire in the spare carrier. It is the cable type. I have a 32x11.5" spare tire in there now and it is a very tight fit. It does not go all the way up in the front but probably would if I didn't have a receiver hitch keeping it from moving back a little. That 32" tire has less than half the tread on it and that helps it fit. I tried a nearly worn out 33x10.5" tire but that was a complete no-go.
Josh B
1,986
Oklahoma
Have you ever had to get it out while a rear tire was flat?
I wonder if I could rob the hangar off my 96 Explorer and install on the 93 Ranger
