95 97 spindles on stock 88 I bean
Snake PLissken
would like to find out if any one has done this or will they fit before I run out and buy 95 97 front spindle package thank for any info.
JoshT
1,788
Macon/Fort Valley, GA
No that won't work. To run the 95-97 spindles you have to have 89+ beams installed. You are in luck because the 89+ beams will bolt right onto your 88. If you grab the beams from the same donor as the spindles they you should have everything that you need to do the swap.
Snake PLissken
thanks I guess I will just get the whole 95 /97 I beam set up and that will solve a lot of issues
It will be a stronger axle too.
SenorNoob
586
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
JoshT
1,788
Think he was thinking about 4wd there.
