96 Lincoln Town Car Engine Removal Questions?
Craig0320
225
Mississppi
Break it right the first time. Fix it better the next time.
I have an older gentlemen wanting me to swap in a lower mileage engine and transmission into his 96 town car with the same year donor. I have pulled many engines and transmissions but never out of a town car. Is there anything I need to be aware of. I would love to pull he whole package but will separate if it is easier. I haven't looked to see if the core support was bolted or welded yet. Any info would be great.
19Walt93
4,467
Canaan,NH
351
3"
235/55R16
That's basically a conceited Crown Vic with a weight problem, we never pulled a core support on a Crown or tried to pull the engine and transmission as an assembly. I'd want to replace the rear main seal and front pump seal before installing used components anyway.
Craig0320
225
Mississppi
I usually do replace the seals. Most likely I will pull them separate. Sometimes it takes 3 times as long trying to take the easier route.
