98 2.5L runs rough.....
flaymon1
Pendleton, IN
2.5
the engine sounds like its runing on two cylinders or the timing is off...... But I've reset the timing and installed plugs, wires, and coil packs, PCM,.........any thoughts guys
caveman_joey
Fitzgerald, GA
stock 4 banger
You could try disconnecting or unplugging the MAF (mass air flow sensor) and see if that make any difference. Its quick and easy and would eliminate that out of the situation to move forward from.
flaymon1
Pendleton, IN
2.5
I didn't get a mass air code.......I'll give er a try
tomw
46
lima bean
vertical and above ground
You could disconnect one plug wire at a time to see the effects... Check fuel pressure? Check fuel flow using a gauge, container and bleed hose. Key on, and catch the gas in a container, measure flow over 10 seconds and multiply to see if adequate. A leaky PCV or hoses can cause bad running, as can a stuck EGR or leaky vacuum lines.
tom
PetesPonies
25
east coast
2.3l
You reset the timing?? and how did you do that?
flaymon1
Pendleton, IN
2.5
rotated the the number one piston to top dead center alined the timing marks and installed the belt.................could a blown head gasket cause it to run speratic like its out of time.......the truck seems to have lost some coolent since bringing it home....nothing in the oil or on the driveway......maybe shes leaking coolent into a cylinder:icon_confused:......? any thoughts
PetesPonies
25
east coast
2.3l
Run the EEC IV diagnostic feature. It will do a running test on the system and report what it finds.
tajvelocity
CinciTucky
Mazduh
2.5 Kittens
I had a lean on bank 2 code for forever. The truck idled poorly, would stall, poor gas mileage. Finally I found a badly cracked vacuum hose and replaced that. That fixed it.
96fordranger
indiana
2.3
check the fuel pressure, it should be 40 psi+
did you check that the balancer did not slip. havent paid enough attention on these engilnes to see if they can do it but sometimes the outter rings on the balancer can turn and basicly give you a false reading i had it happen to me on a 250 in my granada. have a compression test done to see if its a head gasket
flaymon1
Pendleton, IN
2.5
did a compression test today I had 180psi on cylinders1-3 but on cylinder4 I had 210psi....whats a normal pressure 210 or 180
PetesPonies
25
east coast
2.3l
They both are a bit high. You need to be within 15% ,which those are, but I question whether they really are that high.
flaymon1
Pendleton, IN
2.5
I unplugged the coil packs removed each plug and cranked the engine over and those are peak pressures....
rangergi
san diego
I2.5
You said any thoughts... Tps? I had a low voltage code on that and it made my truck run rough and stall out.
flaymon1
Pendleton, IN
2.5
how did you fix your low voltage problem, what caused it
flaymon1
Pendleton, IN
2.5
okay I put it back together and at idle I began pulling the pairs of wires off the coil packs.....you could here it drop each cylinder till the number 4 it made no difference so its down a cylinder the number 4 cylinder........its arcing at the coil pack....would a bad injector cause it
No members online now.
