99 ranger speedo correction
FORD2011
ann arbor michigan
3.0 flex fuel...71 351 W
i have a 99 ranger, 4x4 xl, came with 215 originally, just put 235s on it and i know the speedo is off, but how do i change it. can i change it through the obd port?
Earl43P
38
Farmington, Pa
Ford F250 4WD
I believe a 99 will need a Ford dealer electronic tool to change the tire size in the 4WABS module.
Since larger tires than yours WERE available stock, that reflash shouldn't be a big deal.
Shouldn't cost more than an hour of labor.
My 2000 came stock with 245/75-16.
If it's RABS, the same reflash is possible at Ford, but I believe that one is done to the PCM.
When I reduced my tire size, I simply printed out a speedo correction chart and kept it on the visor. My change was 5.2% going from 245/75-16 to 235/75-15. My speedo indicated faster than actual.
http://www.miata.net/garage/tirecalc.html
AllanD
135
East-Central Pennsylvania
1987... sorta
'93 4.0
You probably just made the speedo CORRECT, as 215 tires were NEVER stock equipment on a 4x4 1993 or newer.
So some assole put smaller tires on it before you got it and you JUST reinstalled the correct size...
I really doubt that anyone stupid enough to put 215's on a '99 would have the speedo corrected.
AD
FORD2011
ann arbor michigan
actually because it was a xl not xlt it came stock with 215. still has original door sticker, 215/75/15
Toms01PSD
37
Sanford, NC
7.3
Post a picture as proof. I had a 99 4x4 XL model and the door sticker specified 235/75R15.
FORD2011
ann arbor michigan
pic of door tag
original door. original sticker. now whos the idiot. the 99 ranger xl bottom base model had 215s!
FORD2011
ann arbor michigan
4th line down if you need help with that too
Toms01PSD
37
Sanford, NC
7.3
Easy there turbo, I didn't call you an idiot and neither did anyone else. I simply asked to see a picture because I have never seen that. I had the base model 99 4x4 xl as well, that's why I was curious.
