ABS AND BRAKE LIGHT ON
redcloud
6
Mexico
Mazda B2500
2.5 (4 Cylinder)
2.5
235/75/R15
HI
I HAVE A SITUATION WITH MY TRUCK
ABS AND BRAKE LIGHTS ARE ONE, I ALREADY REPLACE ABS SENSOR AND PIGTAIL.
THE 4 TIRES ARE IN THE CORRECT PSI AND BRAKE FLUID IS FULL.
COULD YOU HELP ME?
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
The ABS light coming on will set a code.
Your first step is to read the codes.
redcloud
6
Mexico
Mazda B2500
2.5 (4 Cylinder)
2.5
235/75/R15
THATS A PROBLEM, THERE ARE NO CODES :(
8,370
Check Parking brake switch
If parking brake pedal is down even a little RED Brake light comes on and then ABS light
Pull release handle and lift pedal up with your foot, see if RED light goes off
If not look for the switch, if it or its wire is grounded you get what you have now
Its the white switch in this picture: https://farm4.static.flickr.com/3397/3593897441_bbfa91e6b4.jpg?v=1244094169
Unplugged
But I think that's a 1993 Ranger
redcloud
6
Mexico
Mazda B2500
2.5 (4 Cylinder)
2.5
235/75/R15
redcloud
6
Mexico
Mazda B2500
2.5 (4 Cylinder)
2.5
235/75/R15
Unplugged
I will check tomorrow the brake pedal switch
redcloud
6
Mexico
Mazda B2500
2.5 (4 Cylinder)
2.5
235/75/R15
Hi
As an update
The ABS and Brake light turn on until I put transmission in R
If I disconnect Master Cylinder, Brake light comes off
Every fuse is working
Emergency Brake is working but light still doesn't come on or off and Is correctly connected it
I check Differential Fluid and its a little low, I will refill it tomorrow
rusty ol ranger
2.9 Mafia-Don
7,502
Michigan
177 CID
Your speedometer working?
My 97 F250 did this and it was the speed sensor on top of the rear axle. Or is that what youre calling an ABS sensor?
redcloud
6
Mexico
Mazda B2500
2.5 (4 Cylinder)
2.5
235/75/R15
Yes, with my truck there abs and speed sensor is the same located at the rear differential
