AIR DOOR ISSUE
PINTHEUS
Toledo
FORD RANGER XLT
3.0 FLEX FUEL V6
NOT SURE 3" TO 4" maybe
245 75 R16
I have a 99 ranger 4x4 stepside,I replaced the blend door actuator because my a/c would switch from dash vents to defrost vents whenever it chose to as well as what I now realize was the actual air door rattling furiously at times,now a/c only comes out of defrost vents,I ordered a new air door because I figured it may have a broken pivot point,so I"M WONDERING if anyone knows how to access the air door without removing the dash or cutting the box ? THANKS
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I saw a YouTube video of a guy that cut a hole in thebottom of the EVAP case and changed the door.
PINTHEUS
Toledo
FORD RANGER XLT
3.0 FLEX FUEL V6
245 75 R16
yeah I saw that too,,trying to avoid cutting tyvm
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Remove the dash then...
Not sure you wl have a choice.
PINTHEUS
Toledo
FORD RANGER XLT
3.0 FLEX FUEL V6
245 75 R16
might not ,just checking on options
sebastian323
24
Merced, CA, USA
Ranger XLT
So the dash has to come off... Where do you recommend buying the blend door motor? If I have to do all that work I want to get it from a reliable source. My 1996 blend door is jammed and I only have heat available... Is there apossibility to swap in an older mechanical HVAC system? I have a 1996 XLT
