Axle shaft slip joint
ab_slack
12
New Joisey
2.9L
Looks like I finally need to pull apart my right axle shaft again as the final u-joint has gone.
Since I'll be pulling this apart, for the slide joint (not sure of proper name) on this axle shaft, what is the proper type of lube/grease that should be used.
And while I am under there I think I may drop the front drive shaft and make sure that is good because it is easy. What would be the right type of lube/grease for the driveshaft to transfer case splines?
Thanks
I've always used PTFE grease.
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
That part is called the slip-yoke, or sometimes, slip-joint.
CV joint lube (extreme-pressure molybdenum grease) has always worked well for me.
