Axle shaft slip joint
ab_slack
12
New Joisey
2.9L
Looks like I finally need to pull apart my right axle shaft again as the final u-joint has gone.
Since I'll be pulling this apart, for the slide joint (not sure of proper name) on this axle shaft, what is the proper type of lube/grease that should be used.
And while I am under there I think I may drop the front drive shaft and make sure that is good because it is easy. What would be the right type of lube/grease for the driveshaft to transfer case splines?
Thanks
3,615
I've always used PTFE grease.
4x4junkie
585
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
That part is called the slip-yoke, or sometimes, slip-joint.
CV joint lube (extreme-pressure molybdenum grease) has always worked well for me.
