- Aug 6, 2007
- 1,734
- Macon/Fort Valley, GA
- Ford
- Engine Type
- V8
- 2WD / 4WD
- 4WD
What battery to use?
2000 Explorer 5.0L going into 1999 Ranger. Explorer used a Group 65 battery at ~750 CCA. The Ranger calls for and fits a Group 59 at ~590 CCA and I assume that is the size actually in my truck.
When I bought the donor explorer I took the battery from my Ranger along for the ride not knowing what to expect, and planning ot drive it home. Good thing I did because the battery they had installed was laid over at an angle to fit and was leaking. Didn't say anything and after getting down the road a ways we swapped the battery out. It started fine and mde it home. Have used that battery to start it another time or two since, but looking at the specs it is under rated for the engine.
Unfortunately the Group 65 won't fit in the Ranger's battery tray. The Ranger's battery tray appears to be spot welded to the inner fender and core support so not exactly easy to remove (ignoring the cutting option). Even if it was easy to remove the Explorer's tray wouldn;t fit without rearranging everything on that fender, and I think one of the mounting points would be out in empty space.
So my question for all of you running a 5.0 swap is what battery are you using? Explorer's battery? Ranger's battery? Something else, and if so, what?
For those with a 98+ Ranger, maybe 93+ if battery tray is the same, what did you do? Keep what fits in the tray, or swap tray over as well?
I want to hit the easy button and just use the Ranger battery, but I don't want to get bit in the back side by the lack of CCA.
